Dubai Offroaders Technical Technical Articles and Reviews Soft Shackle
Soft Shackle
Post Mon Nov 19, 2012 8:53 pm
Chris User avatar
Captain
Captain
Real Name: Christiaan Roeleveld
Mobile Number: 562443767
Vehicle Make & Model: Alfa Romeo 159, Westfield SE
Number of drives: 16
Just for my curiosity: Would it be better to have a soft shackle with lower rating then your snatchstrap or higher? In other words, which part do we want to fail first? The strap or the shackle. In case of a metal shackle I think I would want my strap to fail instead of the shackle because that would be less dangerous. But what about when we use a soft shackle?
if you didn't break it, you didn't learn anything.
Post Tue Nov 20, 2012 10:56 am
AJS General - Co Founder
Mobile Number: 50
Number of drives: 0
In my experience, I have seen shackles failing the most, followed by recovery straps/winch cable. This is probably because a) very few people use rated shackles and b) many a times, shackles are put into the recovery point in such a way that the shackle bolt takes the contact with the metal recovery point, and hence takes the load at its weakest link.
Moreover, we talk about shackle risks more often because the broken pieces of shackle fly like bullets and are prone to hit people in all directions and that too far away from the site of the accident . A broken strap can also be fatal if someone is standing within its range, but this range is limited to the length of the flying strap. Therefore a broken shackle is potentially more dangerous than a broken strap. A soft shackle is also prone to breakage if stretched beyond its capacity but doesn't hurt anyone except the pocket ;) of its owner.
In any case, what fails more often doesn't and should not matter. Our choice of equipment should be such that we have enough margin-of-safety in terms of load being pulled. From this angle, both shackle and strap should be rated for a MINIMUM of 150% (preferably 200%) of the all-up weight of the stuck vehicle.
my 2 cents on the subject
ajay
Mark your tracks on a clean slate.......
Post Tue Nov 20, 2012 11:00 am
Mobile Number: 50
Number of drives: 0
zarir wrote:
Update on the availability.
Ramy - Said does not have / keep soft shackles
Icon - Keeps the Marlow 4 Ton ones. Selling for AED 195 but currently out of stock.
Blingmytruck.com - Keeps the Liros 6 Ton and 10 Ton. Currently only 6 Ton in stock (Discounted price is AED 160). The 10 Ton is expected soon (Discounted price is AED 180).
for our requirements, 6 ton is good enough, but are these prices for a pair or per piece. these shackles generally come in pairs, so please check out
ajay
Previous
Return to Technical Articles and Reviews
